Alfa Romeo 147/156/GT/GTV/Spider Service Schedule
Advice: this is a general service schedule based on Alfa Romeo's service books for the 147, 156 and GT, together with the 916 series GTV and Spider. Different models may vary slightly with year and engine size.
thousand miles > | 12 | 24 | 36 | 48 | 60 | 72 | 84 | 96 | 108 |
Check tyre wear and adjust pressures | X | X | X | X | X | X | X | X | X |
Check front brake pads for wear | X | X | X | X | X | X | X | X | X |
Check rear brake pads for wear | X | X | X | X | |||||
Check condition of lines, power steering and drive shafts | X | X | X | X | X | X | X | X | X |
Check under body, paintwork and all rubber components | X | X | X | X | X | X | X | X | X |
Check condition of Aux drive belts | X | X | X | R | X | ||||
Replace cam belt and balancer shaft belt 2.0l #1 | X | X | X | ||||||
Replace cam belt 1.6/1.8l #1 | X | X | X | ||||||
#1 Cam belt change interval has been reduced for all 4 cylinder petrol engines of all ages to 36,000 as of 13/11/06 or every 3 YEARS, whichever is sooner | |||||||||
Replace Cam belt V6 and diesel #2 | X | ||||||||
#2 We recommend a change interval of every 60,000 at the latest on V6/diesel engines, remember the interval is also every 5 YEARS, whichever is sooner | |||||||||
Check and adjust hand brake | X | X | X | X | X | X | X | X | X |
Check valve clearances (diesel) | X | X | X | X | X | ||||
Check fuel vapour recovery system | X | X | |||||||
Replace fuel filter (diesel) | X | X | X | X | X | X | X | X | X |
Replace air cleaner petrol | X | X | X | X | |||||
Replace air cleaner diesel | X | X | X | X | X | X | X | X | X |
Check and top up levels | X | X | X | X | X | X | X | X | X |
Replace spark plugs | X | ||||||||
Check on Examiner | X | X | X | X | |||||
Check gear oil level | X | X | |||||||
Replace engine oil and filter | X | X | X | X | X | X | X | X | X |
Renew pollen filter (extra charge) if fitted | X | X | X | X | X | X | X | X | X |
Test brake fluid | X | X | X | ||||||
Check hood operation and top up if required | X | X | X | X | X | X | X | X | X |
Reset service counter | X | X | X | X | X | X | X | X | X |
Road test car, checking all lights, wipers, etc | X | X | X | X | X | X | X | X | X |
Related Links: 159/Brera/Spider 18,000 service schedule | Fixed Price Servicing | Servicing Alfas under warranty | Getting the best out of your Garage | Tyres - All You Need to Know
