Prices include VAT and we use Genuine or Original Equipment parts and Selenia 20K oil.
To see the operations carried out on our services go to 'Schedule'
| Mileage | 1.6/1.8 litre | 2.0 litre | 2.5/3.2 litre | JTD/MJET |
| 12,000 | £166.72 | £167.67 | £201.72 | £237.49 |
| 24,000 | £287.52 | £285.96 | £246.52 | £311.49 |
| 36,000 | £266.72 | £267.20 | £239.72 | £237.49 |
| 36,000 inc cam belt * | £521.12 | £571.20 | ||
| 48,000 | £191.52 | £193.96 | £336.56 | £335.49 |
| 60,000 | £308.80 | £311.24 | £421.72 | £237.49 |
| 72,000 | £265.52 | £267.96 | £252.56 | £311.49 |
| 72,000 inc cam belt */** | £537.92 | £586.32 | £1,034.92 | £713.51 |
| 84,000 | £166.72 | £167.20 | £201.72 | £237.49 |
| 96,000 | £235.52 | £236.36 | £242.56 | £407.49 |
| 108,000 | £266.72 | £267.20 | £239.72 | £237.49 |
| 108,000 inc cam belt * | £521.12 | £571.20 | ||
| * From 13/11/06 the official cambelt service interval on all 4 cylinder petrol engines of all ages was reduced to 36,000 miles (or 3 years - whichever is sooner). | ||||
| ** The offical interval on V6 and diesel engines stay at 72,000 (or 5 years - whichever is sooner), which in our opinion remains too long. The diesel cam belt changes now include a water pump | ||||
Should you wish to use other specific items for your service (eg Selenia Racing or HPX oils) we can easily substitute the parts and the cost will be adjusted accordingly.
Fixed Price Service Repairs
| Braking | Front (NOT GTA) | Front GTA | Rear (NOT GTA) | Rear GTA | All Models |
| Brake pads | £152.40 | £174.00 * | £152.40 | £152.40 | |
| Brake pads and discs | £197.00 | £384.00 * | £180.00 | £218.40 | |
| Hand brake cable RIGHT | £55.60 | ||||
| Hand brake cable LEFT | £60.40 | ||||
| Brake hose | £99.80 | £100.80 | £104.60 | £104.60 | |
| Brake fluid replacement | £75.20 | ||||
| _____ * Prices are for the late GTA with the 330mm discs, for prices for the earlier model with 305mm discs please call. ______ | |||||
| Suspension | Front Right | Front Left | Non Sided | Rear Right | Rear Left |
| Upper wishbone | £122.40 | £124.80 | |||
| Lower wishbone | £200.00 | £200.00 | |||
| Roll bar link | £45.00 | £45.00 | £53.40 | £53.40 | |
| Front roll bar | £406.00 | ||||
| Front roll bar V6 | £508.00 | ||||
| Radius arm | £124.00 | £124.00 | |||
| Hub bush | £89.64 | £89.64 | |||
| __________________________________________________________________________________________________________ | |||||
| Other services | T/S & JTS | 2.5/3.2 litre | Diesel | All Models |
| Radiator (inc anti freeze) | £374.00 | £377.50 | 1.9 £350.00 | |
| Air conditioning re gas | £91.20 | |||
| Cam belt replacement | 1.6/1.8 £260.00 2.0 litre £325.00 | £848.40 | Inc pump £350.00 | |
| Thermostat (inc anti freeze) | T/S £114.95 JTS £0.00 | |||
| Water pump (inc anti freeze) * | £63.05 | £288.14 | ||
| Spark plugs * | T/S £152.08 JTS £132.30 | £92.00 | ||
| Variator * | £300.00 | |||
| Auxiliary belt, tensioner & idlers | 1.6/1.8 £185.60 2.0 litre £138.09 | £285.00 | 1.9 £225.20 2.4 £314.24 | |
| MOT | £54.85 | |||
| ________________*Prices are for fitting parts ONLY when replacing the cam belt at the same time ________________ | ||||
If you require a service price that is not listed here then please use this link jamie@alfaworkshop.co.uk or phone us on 01763 244441
