Prices include VAT and we use Genuine or Original Equipment parts and Selenia oil.
If you want to book a service with us, simply click on the relevant service price and follow the instructions
To see the operations involved in our services go to 'Schedule'
Petrol cars servicing
| Mileage >> | 9,000 | 18,000 | 27,000 | 36,000 | 45,000 | 54,000 | 63,000 | 72,000 | 81,000 | 90,000 |
| 2.0 Litre petrol | £233.99 | £359.99 | £271.19 | £479.57 | £233.99 | £385.19 | £233.99 | £509.57 | £271.19 | £359.99 |
| 2.9 Litre petrol | £357.14 | £527.14 | £357.14 | £1,763.13 | £357.14 | £527.14 | £357.14 | £1,742.13 | £357.14 | £527.14 |
| ____________________________________________________________________________________________________________ | ||||||||||
Diesel car servicing
| Mileage | 12,000 | 24,000 | 36,000 | 48,000 | 60,000 | 72,000 | 84,000 | 96,000 | 108,000 | 120,000 |
| 2.2 Litre Diesel (150/180hp) | £223.98 | £325.98 | £449.58 | £325.98 | £981.32* | £419.58 | £223.98 | £457.98 | £377.58 | £1,025.32* |
| 2.2 Litre Diesel (210hp) | £211.98 | £313.98 | £437.58 | £313.98 | £969.32* | £407.58 | £211.98 | £445.98 | £365.58 | £1,013.32* |
| ____________________________________________*Cam belt service_____________________________________________ | ||||||||||
Braking
| Model | Front pads | Rear pads | Front pads/discs | Rear pads/discs |
| 2.9 | £290.40 | £276.00 | £950.40 | £936.00 |
| 2.2 | £336.00 | £279.60 | £564.00 | 320mm £507.60 292mm £501.60 |
| 2.0 | £258.00 | £213.60 | £426.00 | 320mm £375.60 292mm £366.00 |
| Engine services | 2.0 Petrol | 2.2 Diesel | 2.9 Petrol |
| Oil and filter replacement | Up to 18/06/2021 £202.29 | Up to 2019 £210.28 After 2019 £200.24 | up to 18/06/2021 £251.04 After 18/06/2021 £279.84 |
| Replace auxiliary belt | £1,071.72 | ||
| Replace cam belt and water pump (including centrifugal filter) | £681.84 | ||
| Replace transmission sump pan and oil | £522.00 | £522.00 | £744.00 |
| Segregator/centrifugal filter | £255.04 | ||
| Replace multiair unit (includes oil change) | £2,070.69 |
| Other services & repairs | 2.0 Petrol | 2.2 Diesel | 2.9 Petrol | All models |
| Engineers Report (Overall vehicle mechanical condition) | £120.00 | |||
| MOT | £54.85 | |||
| Air conditioning re gas | £215.15 | |||
| Replace non start/cut out relays | £146.80 | £146.80 | ||
| Install radar anti theft armour | £252.00 | £252.00 | £264.00 | |
| Replace prop shaft coupling (4x4) | £462.00 | |||
| Rear brake actuator wiring harness | £68.80 R/side £78.40 L/side | £68.80 R/side £78.40 L/side | ||
| Replace fuel lifter pump and control unit | £765.60 | £732.00 | £909.60 | |
| Main coolant radiator | £890.00 | |||
| Air conditioning drain mod (stops water in the footwell) | £120.00 |
If you require a service price and it is not listed here please use this link jamie@alfaworkshop.co.uk or phone us on 01763 244441
Should you wish to use other specific items (eg Selenia Racing or HPX oils) we can easily use the parts you require and the cost will be adjusted accordingly.
