This page:
Alfa Romeo Giulietta 54,000 mile, 90,000 km service
pressure, dont forget to check the tyre side wall for damage and bulges while you are there. |
Check all lights dont forget side lights, hazard lights, interior lights and dash lights. |
Check fluids, screen wash engine coolant level and strength. |
Check emissions and check engine management system on examiner. |
Inspect bodywork and underside of car for damage and check aerodynamic aids, pipes and hoses, brake lines, rubber boots and gaiters. |
Check wiper blade condition and make sure screen washers work and hit the screen. |
Check condition of brake disks and pads and wear warning indicator. |
Replace air filter |
Check and lubricate all door locks and bonnet catch. |
Check and adjust handbrake. |
Check accessory drive belt. |
Replace spark plugs. |
Check TCT gear box oil level |
Check brake fluid for water content, if unable to do so change brake fluid every two years. |
Replace pollen filter. |
