This page:
Alfa Romeo Giulietta 18,000 mile, 30,000 km service
Check tyre tread depth and pressure, dont forget to check the tyre side wall for damage and bulges while you are there.
Check all lights dont forget side lights, hazard lights, interior lights and dash lights.
Check fluids, screen wash engine coolant level and strength.
Check emissions and check engine management system on examiner.
Inspect bodywork and underside of car for damage and check aerodynamic aids, pipes and hoses, brake lines, rubber boots and gaiters
Check wiper blade condition and make sure screen washers work and hit the screen.
Check condition of brake disks and pads and wear warning indicator.
Change oil and filter.
Replace air filter
Check and lubricate all door locks and bonnet catch.
Check and adjust handbrake.
Check accessory drive belt.
Replace spark plugs.
Check TCT gear box oil level
Check brake fluid for water content, if unable to do so change brake fluid every two years.
Replace pollen filter.
